Activity Forums Boris FX Particle Illusion How can I automatically change emitter libraries from within Particle View?
  • How can I automatically change emitter libraries from within Particle View?
    Posted by Tia Bradford on June 20, 2009 at 10:35 pm
    Is it possible to view the entire emitter library from Particle View? If I hit Left and Right arrow keys I can scan through a single emitter library, but I cannot scan the entire library of emitters. Have I done something wrong, or do I have to load every library separately to view it?
    Tia Bradford replied 17 years, 3 months ago 2 Members · 2 Replies
  • John Holste
    June 22, 2009 at 12:25 pm
    Tia,
    you can do an empty search in particleView and then click each emitter in the list. To do an empty search press the “S” key to bring up the search window, leave the search textbox empty, be sure to click the “Or” option and the click “Search”.
    Have Fun,
    John
  • Tia Bradford
    June 22, 2009 at 1:53 pm
    Thank you very much. I will try this solution.
