Activity Forums Maxon Cinema 4D How can I attach lights to the corners/points of my cloner object? C4D R16 file attached
  • How can I attach lights to the corners/points of my cloner object? C4D R16 file attached
    Posted by Christian Vilderman on February 2, 2015 at 5:24 pm
    Hi
    I was wondering if someone could explain to me how I can attach lights/nulls to the points/corners of what my animated cloner object has produced. I cant seem to select the points I want to and only can select the points of the original object before I used the cloner. Thanks
    Is this clear enough?
    Christian 🙂
    Christian Vilderman replied 11 years, 7 months ago 2 Members · 3 Replies
  • Brian Jones
    February 2, 2015 at 8:02 pm
    – put your Platonic cloner in a Connect object
    – put a Light/Null in a cloner set it to Object drag the Connect object into the Object tab/Object slot
  • Christian Vilderman
    February 2, 2015 at 8:12 pm
    Hi
    thanks!!!!! seriously. thank you.
    Sorry but now when I try and export the lights to after effects cc all that appears is the camera and a missing png?
    Never encountered this problem before. Any advice?
    Do I need to add a external compositing tag to somewhere in particular. Really confused about this.
    Cheers
    February 2, 2015 at 8:18 pm
    Ok. So I solved it by deleting HDRi RIG and added multi pass all lights. I also added a external composting tag to the cloner with the light.
    Now the question is which one of these amends really solved the problem haha.
    Cheers man
