Activity Forums Adobe After Effects Expressions How can i add an Expression to define OutRender Point like the tag with letter “N”?
  • How can i add an Expression to define OutRender Point like the tag with letter “N”?
    Posted by Adrián Wulfrath on March 23, 2016 at 10:27 pm
    Actually i want to create a dropdown menu to select different comps and activate / deactivate the selected comp. But the problem is that each comp, have different render frames, and i want to define the OUT Render time with an expression when i select that comp in the dropdown menu.
    For example: DROPDOWN MENU: COMP 1, COMP 2, COMP 3.
    COMP 1 have 200 frames for render and the output in render i need is exactly that 200 frames
    COMP 2 have 500 frames for render and the output in render exactly 500 frames.
    bla bla bla ETC.
    Pls help.
    Any idea????
    Adrián Wulfrath replied 10 years, 5 months ago 2 Members · 10 Replies
  • 10 Replies
  • Miguel De mendoza
    March 25, 2016 at 10:32 am
    You can calculate the number of frames of each comp like this:
    var curCompFrames = curComp.duration/curComp.frameDuration;
  • Adrián Wulfrath
    March 28, 2016 at 10:02 pm
    But where i apply that Expression???
  • Miguel De mendoza
    March 29, 2016 at 10:47 am
    How are you creating the dropdown menu?
  • Adrián Wulfrath
    March 29, 2016 at 11:24 pm
    im just turn on / off different comps in the dropdown menu, but each comp have different number of frames, so when i select one option in the dropdown menu i want to change the in/out render trim (i dont know what is the name of that render bar).
  • Miguel De mendoza
    March 29, 2016 at 11:47 pm
    It’s a little confusing what are you trying to achieve. What “dropdown menu” are you talking about? In advance I can tell you that you can only change the in/out point of the work area by hand or by script, not by expressions. If you can give more info about your project, maybe I can help 😉
  • Adrián Wulfrath
    March 30, 2016 at 12:13 am
    Ok, here is the .AEP 9930_test.aep.zip
    I want to change the render time depending on the dropdown menu selection.
  • Miguel De mendoza
    March 30, 2016 at 12:22 am
    The file give me a message of a missing effect called “Dropdown”, I never heard about that effect/plugin and I cant’t find anithing about it on the web, so I can¡’t help you with that effect. What I can tell you is that if that effect dont have that trim functionality you must go on scripting.
  • Adrián Wulfrath
    March 30, 2016 at 12:23 am
    That effects its a pseudo effect, the missing alert doesnt matter because as you can see that effects is working perfectly.
  • Miguel De mendoza
    March 30, 2016 at 12:30 am
    Yes, I can see is a script generated dropdown menu, that simply changes the opacity of the layers by a expression on such property, so you cant achieve what you are trying because YOU CAN’T CHANGE THE IN/OUT points of the work area by expressions.
  • Adrián Wulfrath
    March 30, 2016 at 12:36 am
    well thank you anyway. NP, but is there an expression to trim?? or otherway to resolve that?
