Activity › Forums › Adobe After Effects › How can I add an animated white boiling egde line ?
  • Tim Kurkoski
    December 19, 2005 at 11:29 pm
    Very quickly off the top of my head (without testing to see how well it works);
    1. Auto-trace
    2. Stroke
    3. Scribble
  • David Mattock
    December 20, 2005 at 4:03 pm
    HI, Thanks for your response, really helped !
    Ive messed around with the settings and different effects to scribble but the line seems very jaggy?.. any other suggestions, i need it smoother and have a slight wobble
    Also the traced mask seems to sometimes be out of sync and lag behing the footage it was auto traced from? how can I fix this ?
    Thanks again
  • Tim Kurkoski
    December 20, 2005 at 4:28 pm
    You’ll probably need to refine the auto-trace settings to get it to match your footage closely. It’s probably picking up edge pixels off the bluescreen key (a tighter/more accurate key would also help). Try upping the tolerance and threshold values a little. Usually I have to experiment- try some settings, scrub the timeline to see how the mask looks, undo, try again.
    As for the scribble, try playing with the Stroke Options in the Scribble effect. You should be able to get the look you want from there. It does tend to be a little jaggy, so you might want to move the scribbled mask to it’s own layer, then apply a very slight blur or glow to smooth out the edges.
