Activity › Forums › Maxon Cinema 4D › How are these video clips mapped onto these surfaces in this old show open?
  • How are these video clips mapped onto these surfaces in this old show open?
    Posted by Zachary Hunter on August 30, 2020 at 3:40 am
    In the intro to this old HBO show, probably from 2005ish:
    https://www.youtube.com/watch?v=MsDYEQl1Sy0&t=46s
    How are the videos/ images mapped onto these 3D surfaces? How do they mix it with the existing textures on the surfaces? I’m assuming it’s not done in the 3D program, for flexibility sake.
    My first assumption is that the only way to do this would be to use a UVW Pass with some sort of plugin for After effects that let’s you take advantage of the UV data to place images onto the pre-rendered surface (ft UV Pass), similar to what Nuke does with the ST Map node, and then change the blending mode to like “Add” or “Screen” so it blends with the existing texture of the 3D surface?
    I feel like the UV pass way may be cumbersome, because the UV’s have to be dead on perfect so there is no stretching or distortion, and they can’t tile either or else the video would repeat…..
    Unless there is another easier and better way to achieve this effect that I’m missing?
    Also, do you think that this intro would have been done in Cinema4D or some other 3D program?
    Michael Szalapski replied 6 years ago 4 Members · 3 Replies
