Activity Forums Broadcasting House Reference and sync design…best approach needed!
  • House Reference and sync design…best approach needed!
    Posted by Jay Agoglia on September 25, 2014 at 1:57 am
    Hi Cow,
    I am replacing an old sync generator at my company. This finally gives me the opportunity to set up the house sync/reference and fix what I didn’t set up originally. Until we purchase a Tektronix spg-8000 or something similar. I have a few pieces at my disposal. I’ve been trying to convince the higher ups to let me design a sync patch-bay solution but they are totally against it, and (side note) would really appreciate any response or experience pro-sync patch-bay AND/or NO-sync PB.
    To my current question. we are a post house that distributes to broadcasters. We do not have live video feeds on air/web or any video cameras.
    We use encoders, NLE’s, VTRs, RS422 operations, VTR emulation, Frame Accurate lay-offs, Dubbing, video Conversions, QC, etc.
    What are some suggestions for this type of environment?
    Here is my list of important gear:
    1) Sync generator: Tektronix SCB-200N (4 BB, sync, blank, VI, Enc SC, SC outs)
    2) AJA Gen10 (for tri-level)
    2) DA: Leitch FR-684 DA’s (8×8)
    3) I also have Leitch FR-6804-1 Digital Glue? (havent looked into this yet)
    Two main ideas:
    1) To minimize sync being a potential issue and to quickly isolate if it is an issue when troubleshooting
    2) Most stable wiring for heavy workflows
    Since I have 4 BB outputs and an 8×8 DA…Do I focus on isolating workflow systems with the same grouping of sync signals or grouping identical equipment together, or spreading equipment out.
    I am most concerned about:
    MPEG Decoder boards
    VTRs: SR, D5, Digi Beta, etc
    FCP, Vegas and Premiere NLe’s (AJA Kona LHi boards & one with Kona3)
    Pipeline and other Network Encoders
    For the following workflow what is Ideal:
    Mpeg Decoder board (ref in & can be gen locked)
    EV Encoder 1(no gen lock or reference needed)
    EV Encoder 2 (Sync source can be ref in or video in, can be Gen locked)
    EV Encoder 3 (no gen lock or reference needed)
    Pipeline (Ref in and can be gen locked)
    thank you!
    -Jason
    Jason Agoglia
    QC Manager
    On The Spot Media
    Tom Matthies replied 11 years, 10 months ago 2 Members · 1 Reply
  • Tom Matthies
    October 14, 2014 at 1:50 pm
    The AJA Gen10 is capable of outputting both “normal” and Tri-Level sync. You might consider using its dual outputs and sending each to a DA for distribution to your various pieces of equipment. Do you have equipment that actually requires Tri-level sync? If so, it should be happy with the Gen10 signals. I’m running one in a remote truck and it works well.
    Unless you have a number of “islands” of equipment, you are generally better off running the same reference to everything. You can’t go wrong with everything locked to a common reference.
    If you need something other than simple Black Burst, you might want to consider a more capable sync generator that is capable of a wider variety of output signals, although there isn’t as much of a demand for signals like horizontal drive, vertical drive or blanking as there used to be.
    Not my monkeys. Not my circus.
