Activity Forums Apple Final Cut Pro Legacy Hour Documentary won’t playout
  • Hour Documentary won’t playout
    Posted by John Forsen on October 7, 2008 at 5:46 am
    I’m trying to do a playout on an hour SD documentary, and it keeps freezing, stopping or going out of sync around the 16- 18 minute mark
    I’ve got a Dual 2.7 Power PC with 6 gigs of ram and am using a firewire to a Sony deck.
    Any suggestions?
    JF
    Arnie Schlissel replied 17 years, 11 months ago 3 Members · 2 Replies
  • David Roth weiss
    October 7, 2008 at 6:15 am
    You’re most like dropping frames because:
    a) your hard drive is too full
    b) you need to do a “Mixdown” in the Sequence >> Render Only drop down menu
    c) “Full” is not checked in Sequence >> Render All before rendering.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Arnie Schlissel
    October 7, 2008 at 4:48 pm
    [David Roth Weiss] “You’re most like dropping frames because:
    c) “Full” is not checked in Sequence >> Render All before rendering.”
    Or d) your hard drives are too slow for the material that you’re using- FW400 for uncompressed, for example.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
