Activity › Forums › Adobe Premiere Pro › hot spot in footage
  • hot spot in footage
    Posted by Jessica Robbins on July 18, 2008 at 8:13 pm
    Does anyone know how to neutralize a hot spot in premiere.
    I have a bust shot of a person with a highlight on one side of the face and the other has heavier shadows. We were not able to use a board to bounce the key light.
    Is there a trick to softening the highlight w/o losing the contrast integrity of the frame? I have tried all the little effects and they just are not cutting it.
    Thanks for any advice.
    Jeff Brown replied 18 years, 2 months ago 3 Members · 2 Replies
  • Harm Millaard
    July 19, 2008 at 9:53 am
    Duplicate the clip on a higher track, add a garbage matte to this duplicated clip to cover just the area you want to adjust and add color correction or brightness correction.
    Harm Millaard
  • Jeff Brown
    July 21, 2008 at 1:09 pm
    You can also try a luma key on the duplicate layer to isolate the highlight, then color-correct that.
    -jeff
