Activity Forums VEGAS Pro horizontal lines & quivering stills very annoying
  • horizontal lines & quivering stills very annoying
    Posted by Joseph Dezordi on August 25, 2005 at 11:04 am
    I have quality shots of a moving baby, with great skin tones, everything looks fine when I preview it in Vegas… there are some frames I have ‘snapshot’ from the video & bought them back as events as a jpg ….[ or as PSD after adding layers of effects ]
    After I render this in PAL DV or MPG2, some sections have ugly horizontal lines especially where there is movement, this makes the video look really cheap ….
    also some of the ‘ stills’ have this rapid quivering effect, despite being ‘ stills ‘.. yet, the adjacent event though it is also a frame fozen as a jpeg, looks perfect ,,,
    is this some thing to do with bit rates or I, B, P frames ? [ none of which I understand…?]
    I always render in Progressive scan at full quality
    thanks for your help sorry if my query is muddled, but I am geeting epilepsy from this
    Joseph Dezordi replied 21 years ago 3 Members · 3 Replies
  • Edward Troxel
    August 25, 2005 at 1:28 pm
    After you take the snapshot, load it in Photoshop and deinterlace it. Does that make a difference?
    Edward Troxel
    JETDV Scripts
  • Rick Wise
    August 25, 2005 at 4:55 pm
    I’ve found that even with a still, if the image contains fine lines I have to do all three of these to eliminate flickering:
    –force resampling (right-click, select “properties”)
    –reduce interlace flicker (same thing)
    –insert a velocity envelope and set the speed to zero, forcing a still frame of a still frame.
    Rick
    Rick Wise
    director of photography
    Oakland, CA
    http://www.RickWiseDP.com
    email: Rick@RickWiseDP.com
  • Joseph Dezordi
    August 29, 2005 at 5:54 am
    Thanks, I did these things but the response is inconsistent, there are some images that still flicker like crazy
    I noted that there is a function in Architect to reduce flicker, but that the DVD then takes much longer to encode, & the resulting MPGs or whatever they are are much larger,
