Horizontal lines during capture using Vegas 10
Posted by Nickolas Papastamos on May 27, 2011 at 5:33 amHi
When we are capturing through Sony Vegas 10, I am getting horizontal lines when the camera is panning or slight motion (horizontal fringing lines such as poles, flags, etc.) Very Irritating, this is From capturing from Hi8.We also have the same problem on HDV to DV, but when we capture HDV only, we don’t have this problem.
Any Suggestions Please
TIANickolas Papastamos replied 15 years, 3 months ago 3 Members · 6 Replies -
Danny Hays
May 27, 2011 at 3:20 pmThose are interlace lines. Set your project settings to progressive and blend or interpolate.
John Rofrano
May 27, 2011 at 4:12 pmThat is just interlacing and there is nothing wrong with this. It’s normal for Hi8 footage will not show up when played back on a TV (which requires interlaced video).
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Danny Hays
May 27, 2011 at 4:27 pmMaybe not on a CRT TV, but I can see them on all my LCD TVs and monitors.
(which requires interlaced video)? I must be missing something. -
John Rofrano
May 27, 2011 at 5:40 pm[Danny Hays] “Maybe not on a CRT TV, but I can see them on all my LCD TVs and monitors. “
TV is TV. By definition TV is an interlaced delivery medium. If you are feeding your LCD TV a broadcast signal or signal from a set-top DVD player, your interlaced footage will look correct. If you are feeding your LCD TV from a “computer” (which is not an interlaced device) then you will see the interlacing. You should not remove interlacing unless your target device requires you to do so.
If the original poster is going to deliver the footage on a DVD, it should remain interlaced. If they want to deliver it to a PC or internet, it should be deinterlaced when rendered. In neither case would I recommend setting your project to progressive. It is always better to set your project to match your source footage unless there is a specific reason not to.
If you don’t like seeing the interlacing while editing, just set the options on your Windows Secondary Display to “deinterlace” and Vegas will happily deinterlace it as you preview it. This in no way alters the original video, rendered video, or project settings. It just simulates how it will look on a TV.
~jr
Danny Hays
May 27, 2011 at 6:18 pmOK, That clarifies it. I rarely burn video DVDs since I usually play them from a computer or server.I knew DVD players deinterlace for us.
Thanks for the information John.
