Activity › Forums › Adobe Premiere Pro › Horizontal lines appear after I export my mp4 video in Adobe Premiere Pro
  • Horizontal lines appear after I export my mp4 video in Adobe Premiere Pro
    Posted by Tara Marianne on January 21, 2016 at 2:05 am
    After I export my video in Adobe Premiere Pro as an mp4 these wierd horizontal lines appear whenever there is motion. I’d really like to figure out how to get rid of these because everything else is perfect. Quality is great. I’ve tried exporting as mov, wmv, avi, mp4. Everything has these lines. Please help. Also I have my project setting set to “No Fields Progressive scan” already so that’s not the problem and I’ve tried changing the field to “Deinterlace”. That has no effect either.
    Here is the specific format I used for the current video I’m working on;
    Format: H.264
    Preset: HD720 29.97
    W: 1280 H: 720
    Frame Rate: 29.97
    Field Order: Progressive
    Aspect: Square Pixels
    TV Standard: NTSC
    Profile: Main
    Level: 3.2
    Bitrate Encoding: VBR 1 pass
    Target bit: 6
    Max bit: 10
    Example of horizontal lines when there is motion in video (panning, subject moves etc.)
    Vince Becquiot replied 10 years, 7 months ago 3 Members · 6 Replies
  • Vince Becquiot
    January 21, 2016 at 3:51 am
    Hi Tara,
    Check your sequence settings and see if it’s set to upper fields first, if so change to progressive and see if that solves your issue.
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Tara Marianne
    January 21, 2016 at 6:43 pm
    it is already set to progressive :/
  • Vince Becquiot
    January 21, 2016 at 6:49 pm
    Ok, then try right clicking on every clip in your project manager, then change the interpret settings to progressive as well.
    Vince
    Vince Becquiot
  • Jon Doughtie
    January 21, 2016 at 8:30 pm
    Is your original footage progressive or interlaced?
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2014 (as of 7/2015)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Tara Marianne
    January 22, 2016 at 2:13 am
    How would I figure out if my footage is progressive or interlaced?
    I’m thinking now it has something to do with when I convert my original source footage from MTS to AVI. Because after the conversion is when I notice the lines.I can’t import MTS into Adobe so I convert it first to avi. How would I convert it but avoid getting these lines?
  • Vince Becquiot
    January 22, 2016 at 3:04 am
    That could be harder to solve. Depending on the program you are using, you want to make sure you are keeping the fields in the same order. Most HD formats are either upper or progressive.
    Vince Becquiot
