Activity Forums DaVinci Resolve horizontal line banding in Da Vinci 8
  • horizontal line banding in Da Vinci 8
    Posted by Charles Haine on August 4, 2011 at 8:28 pm
    Cowers,
    Just started getting horizontal stripes in my renders out. Very strange lines streaking across the image at a variety of different heights and different colors.
    You can take a peak at what they look like here:
    https://i272.photobucket.com/albums/jj181/charleshaine/Screenshot2011-08-04at11733PM.png
    Any ideas? I had something similar on some Color renders way back in 2008 that were the result of a video card on it’s way out of the world; I have a GTX 285 and a GT120, maybe the 285 is starting to go.
    Any way to test it? It’s the only CUDA card I’ve got so I’m not sure how to swap it out with another without maybe going to buy one and returning it if it doesn’t fix the problem.
    I’ve cranked render speed down to 1 and the error still shows up, in case that would’ve eased the burden on the card.
    thank you,
    Ch:H
    Charles Haine
    Colorist, Professor
    ColorCorrection.Com
    Dan Moran replied 15 years, 1 month ago 2 Members · 6 Replies
  • Dan Moran
    August 4, 2011 at 9:57 pm
    Hi Charles,
    Can you please send your Resolve logs to davincihelp@Blackmagic-design.com
    You can find the capture logs app at
    Library/application support/Blackmagic Design/DaVinci Resolve
    If you double click it and mail us the file it saves.
    I have an idea of what’s going on but I’d like to check the logs
    Dan
    Dan Moran
    DaVinci Application Specialist
    Blackmagic Design EMEA
  • Charles Haine
    August 4, 2011 at 10:33 pm
    Upgraded to 8.01 and that fixed the problem; should’ve tried that before posting 🙂
    Does that jive with what you were expecting?
    Loving everything about Lite and looking forward to upgrading to full resolve sometime soon, thanks for the speedy reply.
    Charles Haine
    Colorist, Professor
    ColorCorrection.Com
  • Dan Moran
    August 4, 2011 at 11:02 pm
    Hey Charles,
    What did you update to 8.0.1 from ?
    This is the first version of Resolve Lite to be released?
    Cheers,
    D
    Dan Moran
  • Charles Haine
    August 4, 2011 at 11:08 pm
    Put Resolve lite on my other machine, to load up the project and see if it was a bad video card, which made me realize that I hadn’t updated my main machine to 8.01.
    Charles Haine
    Colorist, Professor
    ColorCorrection.Com
  • Dan Moran
    August 4, 2011 at 11:17 pm
    Ah sorry sir!
    I just seen you were looking forward to upgrading to the full version and got a little confused!
    Glad your Having fun!
    D
    Dan Moran
  • Dan Moran
    August 4, 2011 at 11:21 pm
    Just as a little extra tip you can always keep the full version installer on your Resolve Lite machine and if you need to use the full version just grab the dongle from your main machine and install the full version.
    Best thing about using a dongle is being able to grab it and move it easily 🙂
    D
    Dan Moran
