Activity › Forums › Apple Motion › Horizontal Jitter Problem
  • Horizontal Jitter Problem
    Posted by Matt Callac on June 9, 2006 at 4:15 pm
    I started having this problem a few months ago with motion. When I create multilayerd comps with a good bit of masking/filtering, I get this wierd horizontal shifting when I render in FCP. The work around has been to export MOV’s straight out of motion. Well I’m having to change some stuff for a comp I did a year ago. When rendered in FCP it jitters something aweful, so I exported it out and get the same thing. Any Idea what may be causing this? It was created in Motion 1.1 and now I’m running 2.0.1. I posted the exported video here(https://www.lapostgroup.com/clients/Matt/) so you can see what I’m talking about. ANy help is much appreciated.
    mattyc
    p.s. graphics card is an ATI Radeon 9600 Pro
    Matt Callac replied 20 years, 3 months ago 2 Members · 4 Replies
  • Doyle Rockwell
    June 9, 2006 at 9:53 pm
    Hey Matt,
    Jitter like that can be caused by exceeding the maximum image size for your graphics card. For a better explanation and some suggestions that might help you implement a fix, check out https://www.motionsmarts.com/tutorials/nutsandbolts/sizematters.html
    Good luck!
  • Matt Callac
    June 10, 2006 at 12:01 am
    All my layers were fixed resolution 720×486.
    -matt
  • Doyle Rockwell
    June 10, 2006 at 6:09 am
    Hey Matt,
    What size (full-size, not scaled) were the images inside those layers? Each step in the compositing pipeline has to be handled by the GPU, so if an image
  • Matt Callac
    June 12, 2006 at 3:38 pm
    All my source video and images are 720×486.
    -mattyc
