Activity Forums Adobe After Effects Horizontal alignment of tracked points in Solve camera module in Mocha Pro 5.0
  • Horizontal alignment of tracked points in Solve camera module in Mocha Pro 5.0
    Posted by Igor Safin on March 3, 2017 at 10:27 am
    I have solved a 3D camera movement in Mocha Pro with a pretty great result. When I import tracked data in After Effects the surface I know is horisontal in life is angled in composition (nulls at the corners of surface)
    Question: Is there way to align surface I know is horizontal in life, horizontally in composition in After Effects (with camera position also be affected relatevely) or before exporting data from Mocha?
    The green line repersents desired result.
    Best regards. Igor
    Igor Safin replied 9 years, 6 months ago 2 Members · 3 Replies
