Activity Forums Adobe After Effects Expressions Horizon and Camera movement
  • Horizon and Camera movement
    Posted by Ole-magnus Saxegard on August 1, 2008 at 4:03 am
    Im building a 360 panoramic world in AE and I`m using Paul Tuersley`s awesome Make Panorama Script to create mountains and hills, and the new Trapcode Horizon plugin to do the sky and clouds. It works fairly well but Horizon doesnt react to the camera`s movement in space, just its rotation/p.o.i.
    I`m wondering if there is any way of linking the scale of the Horizon layer to the camera`s z movement so that it scales up and down as the camera`s moves in and out?
    Appreciate any input anyone might have,
    cheers
    -Ole
    Ole-magnus Saxegard replied 18 years, 1 month ago 2 Members · 2 Replies
  • Trent Armstrong
    August 5, 2008 at 4:31 pm
    Ole,
    I’ve been experimenting with this a little in AE. I have sort of worked out with the use of CC Sphere. It’s necessary to create precomp that is big (twice as long as it is tall) and put the CC Sphere effect on it in your final comp. The use expressions to control the rotation of each axis of the CC Sphere by attaching them to the camera’s rotation.
    You could then attach either put the layer in 3D space or use the camera’s Z position to drive the radius of the CC Sphere. Again, the image has to be big so it doesn’t pixelate.
    Trent
    Trent Armstrong – Creative Cow Leader
    https://www.dallasaeug.com
  • Ole-magnus Saxegard
    August 6, 2008 at 3:15 am
    Thanks heaps Trent, I`ll give that a go!
    Cheers,
    Ole
