Activity Forums Apple Final Cut Pro Legacy hooking up panasonic DV-2500 deck to apple G5 to work with FCP
  • hooking up panasonic DV-2500 deck to apple G5 to work with FCP
    Posted by Arthur Luhn on November 30, 2006 at 8:36 pm
    I want to hook up the 800 firewire from an G5 to the panasonic DV-2500 deck so I can retrieve tape information to work with, in FCP. How do you do that? Do you need an adapter firewire?
    Thank you very much in advance,
    Original Idiot
    Shane Ross replied 19 years, 9 months ago 2 Members · 3 Replies
  • Shane Ross
    December 1, 2006 at 9:14 am
    Why FW800? The deck only has a FW400 connection…just connect it to a FW400 port on your computer. you have a couple of those.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Arthur Luhn
    December 1, 2006 at 11:33 pm
    DV output on the Panasonic DV-2500 is not compatible with either the 400 or 800 port on the G5 so unless I am doing something supremely stupid… It appears to me that the ports on the G5 are 6 points whereas the DV deck port (DV output) is 4 points.
    OI
  • Shane Ross
    December 2, 2006 at 12:05 am
    That is FW400. Just get a 4-pin to 6-pin FW400 cable. This deck has the same configuration on my DSR-11.
    Shane
    Littlefrog Post
    http://www.lfhd.net
