Activity Forums Adobe After Effects Holding y axis whilst bezier curving x and z axis’
  • Holding y axis whilst bezier curving x and z axis’
    Posted by Sam Freeman on June 22, 2012 at 3:04 pm
    Hi guys,
    This might be just me missing something really simple, but is it possible to hold the y axis (say at 540) whilst still manipulating the x and z axis’. I know you can separate the position properties in the animation dropdown, but you loose the ability to use the bezier handles.
    The problem I have is that when I use the bezier handles to make a smooth animation I find the y axis bobs up and down annoyingly on either side of my keyframe. Not normally a problem, but I’m animating a null along a path (as the camera point of interest), and if it moves on the Y it wrecks the look. The only way I can get the bezier handles to not do Y bend this is to use the ‘top’ view and work the handles from there… (the same way I use to get rid of the boomerang effect)
    Would an expression help me out here do you think? Forcing the Y to a set figure?
    Although I’ve been using After Effects for 8 years or so, I’m self taught and I always have the sneaky suspicion I’ve missed something from the basic’s book! Sorry if I have.
    Thanks guys,
    Sam
    CS6
    Walter Soyka replied 14 years, 2 months ago 2 Members · 3 Replies
  • Walter Soyka
    June 22, 2012 at 4:19 pm
    [Sam Freeman] “Would an expression help me out here do you think? Forcing the Y to a set figure?”
    Nice approach. Alt-click the position stopwatch and enter the following expression:
    [transform.position[0],transform.position.key(1)[1],transform.position[2]]
    This expression works with your keyframes, always use the current values for X and Z, and it will always the value for Y from the first keyframe on the layer.
    Walter Soyka
  • Sam Freeman
    June 22, 2012 at 4:54 pm
    Thanks Walter – as always, you’re the man!
  • Walter Soyka
    June 23, 2012 at 3:12 am
    You’re welcome, Sam.
    I should mention that this expression will not affect the motion path itself — that’s driven by the key frames — so the motion path will show Y axis movement that will not occur in preview or render. Working with this expression may be a little confusing unless you keep that in mind.
    Walter Soyka
