Holding Shift Results in Lopsided Shape?
Hi guys, First time I’m having this problem.
When I’m trying to use the shape layer, and I hold shift the shapes become lopsided.
When I try to make a square using the shape tool and hold shift, the result is a rectangle where the height is long but the width is short.
Same for circle, and any other shapes when holding the shift button. Height is way bigger than the length.
I tried restarting after effects but same results
