Activity › Forums › Apple Final Cut Pro Legacy › Holding OPTION key turns on snapping??
  • Holding OPTION key turns on snapping??
    Posted by Aaron D hose on December 12, 2007 at 3:10 pm
    Just recently updated FCP to 6.0.2. When I edit and want to offset audio from video (or vice versa), I generally hold down the OPTION key while adjusting the length of the video or audio tracks of a linked clip on the timeline. All of a sudden, however, holding OPTION turns on snapping, and I’m having to run it off constantly now!!! I never experienced this in FCP 6 or 6.0.1. WHAT happened here!?!? A glitch!?! This snapping issue is becoming increasingly annoying!
    Help…
    David Bogie replied 18 years, 9 months ago 4 Members · 3 Replies
  • Mark Maness
    December 12, 2007 at 4:04 pm
    Yes, it is rather annoying.
    I’ve noticed that its on when you don’t need it and off when you do. Meaning, when I drop a clip onto my timeline, snapping is off. If I look at my toolbar at the top of my sequence window, it shows that snapping is on. Now, if I need to shift a clip up or down the timeline, its on.
    Wow…. it sure is giving me a headache.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Arnie Schlissel
    December 12, 2007 at 4:16 pm
    [Aaron D Hose] “WHAT happened here!?!? A glitch!?! “
    This is why we need to read the release notes before upgrading. From Apple:
    Changes to Snapping Behavior When Performing Shuffle Edits
    Shuffle (or
  • David Bogie
    December 12, 2007 at 6:06 pm
    We’ve seen this posted about three hundred times since the update came out, including once by me. I never read that stuff.
    But I do now.
    bogiesan
