  • Posted by Andres Torres on May 1, 2009 at 9:08 pm
    I’m looking for an expression that achieves a similar effect as the posterize time effect.
    I’d like to be able to control it based on holding frames, not altering the frame-rate of the composition or layer.
    i.e.,
    1 1 3 3 5 5 7 7 9 9…(each frame is repeated once)
    1 2 3 4 5 6 7 8 9 10…(original frames)
    I’m looking for something with a variable I can alter so i can hold for 2, 3, 4…frames.
    Dan Ebberts replied 17 years, 4 months ago 2 Members · 3 Replies
  • Dan Ebberts
    May 1, 2009 at 10:34 pm
    I think this time remapping expressin does what you want:
    n = 3; // number of frames to hold
    f = timeToFrames();
    framesToTime(Math.floor(f/n)*n);
    Dan
  • Andres Torres
    May 2, 2009 at 4:23 pm
    Thanks for your reply.
    Where do I apply the expression?
  • Dan Ebberts
    May 2, 2009 at 4:27 pm
    After you enable time remapping, you apply it to the time remapping property.
    Dan
