Activity Forums Panasonic Cameras HMC 150 When transfering files to FCP audio go out of sync
  • HMC 150 When transfering files to FCP audio go out of sync
    Posted by Dustin Bath on November 11, 2008 at 7:18 am
    Im shooting in PH 1080/24p and when I log and capture into FCP 6.04 the audio gos out of sync with the picture. I have been shooting a documentary and have not been able to figure it out. Now I have been just down loading the raw mts files to transfer later. Has anyone had this problem? Also now that I have unconverted files on a hard drive what is the best solution for me to convert to quicktime without losing any res so that I can import to final cut? Thanks
    Pablo Hill replied 17 years, 9 months ago 3 Members · 6 Replies
  • Noah Kadner
    November 11, 2008 at 6:55 pm
    It’s best to copy over the entire contents of the folders on the SDHC cards to your hard drive, then run log and transfer from there. Not sure why it’s going out of sync- perhaps your sequence settings don’t match?
    -Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
    Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
    https://www.callboxlive.com
  • Dustin Bath
    November 11, 2008 at 8:29 pm
    I will try the sequence settings ans see if that helps.
    Do you know the best way to convert the files to quicktime since now I cant do a log and transfer off my hard drive? Thanks
  • Noah Kadner
    November 12, 2008 at 5:56 am
    You should be able to assuming you’ve copied the entirety of the SDHC card onto your drive- that’s pretty much essential.
    Noah
  • Pablo Hill
    November 16, 2008 at 8:59 pm
    I don’t have a HMC 150, but I’ve been reading a lot about it because I’m seriously considering changing my Z1U’s to HMC’s, and reading about AVCHD I found this:
    https://www.apple.com/finalcutstudio/finalcutpro/support.html
    Click on the video tutorial of “logging and transfer”
    I found it very interesting and a nice version of logging and capture for solid media.
  • Dustin Bath
    November 19, 2008 at 2:03 am
    I just bought a mac pro 8 core 2.8 with 6gigs of ram and now the import time is almost real time which is great.
    But… My audio is still going out of sync on the import. Do you think im missing a plug in?
    And what should my sequence settings be? Altough it is out of sync when watching in the viewing window without even dropping it in the timeline..
  • Pablo Hill
    November 23, 2008 at 3:32 pm
    Are you transcoding to Prores 422 or keeping it in AVCHD????
    Could it be that your sequence is 30p and your video 24p????
    Have you tried capturing at 30p????? does it still go out of sync??????
