Activity › Forums › Audio › Hissy G3 audio
  • Hissy G3 audio
    Posted by Steve Kownacki on February 8, 2013 at 1:14 am
    I’m dazed and confused about the sound I did on Tuesday. I used 2 of my G3 wireless and a G2. Adjusted them all the same. My unit 2 on input 2 seemed to eliminate background noise WAY better than the other 2 units. On-set I swapped xmitters & receivers, mics, batteries, changed channels, banks, freqs, sensitivity; but mixer channel 2 and monitoring the L channel was soooo much cleaner than the other mics. This occurred inside, outside, and all over inside a large retailer.
    5408_locnatsnd.aif.zip
    5409_locspeaking.aif.zip
    Today I tried to re-create this in my office and they are all identical in tone, volume, noise… everything. So I COULDN’T re-create it! Gad. I did every possible combo of mic, xmitter, receiver… all sound identical. AND they all have similar noisy characteristics as they did on set. I couldn’t get that clean channel I did have. They should be cleaner sounding. What I hear in the cans when recording is exactly what the file recorded – as it should be.
    5410_officetest.aif.zip
    In post, this is a piece of cake to clean up, but I don’t want to deliver poor audio and cause work for anyone. I can confirm that there is hiss in the receiver when I plug the headphones directly into the output jack which would eliminate the mixer causing the noise. Mixer was a Sounddevices 522. Everything on battery. Same results no matter how many or few receivers or transmitters on simultaneously.
    Really confused about this, especially since I can’t re-create the issue. Mics worked fine the day before.
    Appreciate your thoughts.
    Steve
    Steve Kownacki replied 13 years, 7 months ago 2 Members · 2 Replies
