Activity › Forums › AJA Video Systems › Hiss on Audio Output of Kona 2
  • Hiss on Audio Output of Kona 2
    Posted by Isoparm on November 21, 2006 at 6:11 pm
    Hello,
    I’ve only used the video output of my Kona 2 card until now. Yesterday I tried to monitor the audio output of my Kona 2 card and discovered that all I hear is a loud hiss.
    I’ve tried 2 driver versions (1.x & 3.3), but that didn’t help. I’ve tried both Apple’s Soundtrack Pro & Final Cut Pro (5.1) and AJA’s TV output program, but got the hiss on all three.
    I was running the Kona 2 XLR cable into a Mackie mixer and also tried a Digidesign MBOX.
    Anybody have any idea on why I’m getting a hiss, and how I might be able to correct this?
    Stuart Ferreyra replied 19 years, 10 months ago 2 Members · 3 Replies
  • Stuart Ferreyra
    November 21, 2006 at 6:29 pm
    We experienced an issue like that when we used the audio output for the first time.
    For a long while we only used the video out just like you.
    The trick is to go to the Mac’s System Preferences – Sound and adjust all audio outputs
    to 64. (adjust the audio level – then move the mouse away from it – then place on the
    level marker again- a tip tool type window will pop up and give you the level number)
    Hope this helps…
    Stuart Ferreyra
    Timecode Multimedia
    President
    Santa Monica, CA 90025
    https://www.timecodemultimedia.com
  • Isoparm
    November 21, 2006 at 9:59 pm
    Thanks for the advice. Turns out the issue is that the Kona’s connections are AES and not analog. I was trying to monitor via an analog source so that was my issue.
  • Stuart Ferreyra
    November 22, 2006 at 4:41 am
    Yeah, that would be a problem.
    Use the RCA outputs for monitor.
    Stuart Ferreyra
    Timecode Multimedia
    President
