Activity Forums Maxon Cinema 4D Hinges and Dynamics in R12
  • Hinges and Dynamics in R12
    Posted by Matt Gerard on December 3, 2010 at 9:43 pm
    Do hinges only work with dynamics? What if I want to connect a series of objects together with hinges, but only want to animate one of the objects and have the others folly according to the hinges? As soon as I attached the dynamics tags to the objects, I lose the ability to set keyframes for those objects, even if I have the dynamics turned off (so they are just collider tags).
    Think of a picture frame made of the 4 separate sides, with a hinge connector at each corner. I want to animate the bottom most horizontal frame piece to swing from left to right, but have the two side rails connected so no matter where I move that bottom piece, the 2 side pieces follow.
    Am I crazy?
    Matt
    Its more fun to ride a slow motorcycle fast than a fast motorcycle slow…
    Matt Gerard replied 15 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
