Activity › Forums › DaVinci Resolve › Highlights
Highlights
Posted by Stig Olsen on September 6, 2012 at 11:03 amHi,
I have some RED-clips with some extreme hightlights. The soft clip or luma gain will not take them, so the only possibility I see is to change the brightness and flut in the raw settings.
Any suggestions?I dont want to change the raw settings as it will affect the entire picture.
Stig
Sascha Haber replied 14 years ago 5 Members · 5 Replies -
Ola Haldor voll
September 6, 2012 at 11:47 amYou kind of rule out your options yourself.
If the image is too dark and produce too much noise when you lift it to acceptable exposure, well.. -
Joseph Owens
September 6, 2012 at 6:53 pm[stig olsen] “Any suggestions?”
Maybe a custom curve (luminance/ganged)?
jPo
“I always pass on free advice — its never of any use to me” Oscar Wilde.
Chad Terpstra
September 6, 2012 at 8:09 pmSoft clip in R9 is actually not as robust as it was in 8 as far as I can tell. Either way for blown out highlights I usually create a separate node and key in just the luminance of the blown portions and a little just below. Then I raise the mids and blacks and lower the highlights while giving it a hue that matches the image or looks good (usually balanced to white or warm). Raising the mids and blacks near the highlights seems to “soften the blow” and lowering them makes them less distracting. Just my taste though, your mileage may vary.
Stig Olsen
September 7, 2012 at 10:50 amThanks for your inputs.
I discovered like you say Joseph – that the custom curves affects the highlights more agressive than the wheels and luma gain. What is the logic behind that? I havent noticed before.
Stig
Sascha Haber
September 7, 2012 at 11:06 amThat was a bug and is fixed in 9 now.
A slice of color…
DaVinci 9b3 OSX 10.8
MacPro 5.1 2×2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+Colorist / Aerial footage nerd
https://vimeo.com/saschahaber
