Activity Forums Adobe Encore DVD Highlight Buttons
  • Highlight Buttons
    Posted by Awhansen01 on August 5, 2006 at 8:43 pm
    I am using Encore DVD and I created a DVD, and in the menu’s, the buttons do not work on a DVD player. But, they do work on the computer. Even the buttons that I used from Encore don’t always work. They show up as vertical lines along the side of the button. What is wrong?
    Awhansen01 replied 20 years, 1 month ago 2 Members · 4 Replies
  • Awhansen01
    August 5, 2006 at 10:51 pm
    and I have the menu as 16×9, i have a low quality dvd player that i can put the dvd in, the highlights work, but the menu is fullscreen
  • Neil Wilkes
    August 6, 2006 at 10:45 am
    Fullscreen sounds like the player is not picking up the aspect ratio correctly to me.
    I have found that Encore 2 is perfectly fine with 16:9 display, even if mixed with 4:3 content.
    What is not standard though is the way both players & TV sets handle this.
    As an example.
    If my old CRT Widescreen set is yturned on & allowed to set itself – all aspect ratio changes happen automatically. As soon as I over-ride one and set it from the remote – it will not switch automatically again until I turn off & back on.
    Check the TV/DVD player settings here.
  • Neil Wilkes
    What player?
    What TV?
    Have you set the opacity correctly in the Menu Colour Set?
  • Awhansen01
    August 8, 2006 at 12:48 am
    i figured it out, it was because the menu was in 16×9, i changed it to 4×3 and it worked fine
