Activity › Forums › Adobe After Effects › High Def to NTSC and PAR
  • High Def to NTSC and PAR
    Posted by Nick Degner on December 20, 2005 at 7:32 pm
    We recently moved into a facility that is native HD video. Our audience is still NTSC. So even though we are creating work in HD, (3D animations, stills and video) we send the work through a converter that dumbs the video down to NTSC by cropping off the sides. The final video looks as if it is slightly stretched. I am assuming because of the Pixel Aspect Ratio in After Effects. Is there any way to compensate for this?
    Jeremy Garchow replied 20 years, 9 months ago 3 Members · 4 Replies
  • Barend Onneweer
    December 20, 2005 at 8:28 pm
    Does it look stretched on your computer display, or on the TV Video output?
    The TV has a different PAR than a computer display (which has square pixels).
    If it looks right on the NTSC monitor, you should be fine.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Jeremy Garchow
    December 20, 2005 at 11:14 pm
    What converter? Hardware or software?
  • Nick Degner
    December 21, 2005 at 2:12 pm
    We are using a hardware solution for our conversion. On the computer the image looks fine but on the video monitor the image looks stretched.
  • Jeremy Garchow
    December 21, 2005 at 4:40 pm
    Hey Nick. can you please explain to me the steps that are involoved to get you from HD to NTSC. It isn’t making sense to me.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
