Activity Forums Adobe After Effects Hiding icons for Lights
  • Hiding icons for Lights
    Posted by Mark Whitney on April 27, 2017 at 11:24 pm
    Subject pretty much says it. Using AE CS6 and can’t find anything in the docs about how to toggle the visibility in the comp window. Is this possible?
    Marcus Rivers replied 3 years, 9 months ago 4 Members · 5 Replies
  • Greg Gesch
    April 28, 2017 at 12:58 am
    Hi Mark, the only way I know of doing it is ctrl+shift+H – but be aware that it turns off layer controls for all layers (bounding boxes etc.)
  • Mark Whitney
    April 28, 2017 at 1:55 am
    Ah. That worked. Didn’t last night. For what I’m doing that works fine as it’s a project using LUX . Not able to find that key shortcut listed anywhere so I better make a note of it.
    Thanks Greg.
  • Walter Soyka
    April 28, 2017 at 2:22 pm
    This is not quite what you’re asking for, but it might be relevant to you. If you’re working with spotlights, you do have the ability to control the display of the spotlight wireframe. With your viewer panel active, go to View > View Options (Ctrl+Alt+U on Windows, Cmd+Alt+U on Mac) and set Spotlight Wireframes to either “Off” or “When Selected.”
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Mark Whitney
    April 28, 2017 at 4:22 pm
    It might. I’ll give it a try and make a note of that anyway.
    Thanks.
  • Marcus Rivers
    November 22, 2022 at 2:57 pm
    Just what I was looking for. Thanks!
