Activity › Forums › Apple OS X › hiding files, password protection
Posted by Alex on January 17, 2006 at 12:29 pmHI
this may be on the posts, thou my search didnt come up with any results. anyways… is there any possibility to hide files (like in windows) or to password protect files/folders in OS X?
thanx
Rocco Rocco replied 20 years, 8 months ago 3 Members · 2 Replies -
Tony! Hulette
January 17, 2006 at 9:20 pm[alex] “is there any possibility to hide files (like in windows) or to password protect files/folders in OS X?”
Yes and no. OS X uses permissions on every file and folder (Unix). Those permissions are related to users. Every user of that Mac should have their own user name and password. If you put anything into your user folder, then no other user should be able to access or see what’s in it (except a couple of sharable folders inside). If you change the permissions on the files and folders on your Mac, you can prevent or allow any other user from reading & writing to them (need to be Admin level user or above, depending on the files). Get info on a file or folder to change its permissions.
If you don’t want someone looking at your Mac while you’re logged in, but maybe stepped away for a few minutes, then you have a few options. If you go to your Security preferences. You can require a password to wake the computer from sleeping or screen savor. Simply put your Mac to sleep before you walk away. You can also have your user account automatically log out after a few minutes of inactivity. Disable auto login as well, if you don’t want someone else starting from your account.
Instead of typing a whole novel on the subject I found a couple of links that should help you. They will tell you how to make files/folders invisible like you originally requested. OS X has a lot of invisible files on it that are very important. Please don’t delete any unless you really know what you are doing:
https://www.macfixit.com/article.php?story=20040519001916749
https://www.osxfaq.com/dailytips/02-2003/02-06.ws
For locking files/folders on OS X you can search for a helper application like CockTail (which does many more things and is a great little application) on versiontracker.com https://www.versiontracker.com/macosx/. Here’s a search I did: https://www.versiontracker.com/php/search.php?mode=basic&action=search&str=lock&plt%5B%5D=macosx&x=0&y=0
Tony!
Rocco Rocco
January 19, 2006 at 1:26 amNot quite what you asked, but here’s what I do:
Open Disk Utility
Select “New Image”
Decide where you want to store it, and
How big you think it should be, and
Select AES 128 encription
Hit Create
Then enter a password (Don’t forget it!!!)
Hit OKYou now have a password proteted Disk Image of any size you want to drag and drop sensitive data into.
