Activity Forums Maxon Cinema 4D hide selected object keyboard shortcut – c4d
  • hide selected object keyboard shortcut – c4d
    Posted by Jessica Ma on May 16, 2014 at 1:12 pm
    What is the keyboard shortcut for hiding selected object in c4d. (and un-hiding objects)
    I have a big scene and a long list so not always easy to hide things from the list.
    Brian Jones replied 12 years, 4 months ago 2 Members · 3 Replies
  • Brian Jones
    May 16, 2014 at 2:36 pm
    there is no hotkey by default but you can add one if you want using the Customize Commands interface (under the Window menu). If you are looking to hide everything so you can work on one object you might want to look at MagicSolo here https://nitro4d.com/blog/freebie/magicsolo/
  • Jessica Ma
    May 16, 2014 at 3:19 pm
    wow that’s awesome thx!! – also another question – I m importing a bunch of stuff from Maya (its a set) and found that all the pivot points of the objects that used to be centered had gone all over the place? Why is that? (i imported fbx)
    Is there are way to avoid that from happening?
    Also is there a Center Pivot button like in Maya?
  • Brian Jones
    May 16, 2014 at 4:16 pm
    I only ever saw Maya’s demo (Learning Edition) a long time ago so don’t know it well myself and can’t answer the first two (though someone probably knows) and I also don’t know about Center Pivot but I wonder if that might be similar to Mesh/Axis Center in C4D
