Activity Forums VEGAS Pro Hi I need a bit of rendering assistance for a low lighting video
  • Hi I need a bit of rendering assistance for a low lighting video
    Posted by Malcolm Williams on December 4, 2011 at 3:54 pm
    Hi I am sort of new to vegas and learning a bit day by day. I’m working on a mobile phone review and I recorded some videos in not too adequate lighting. This is the raw of the video [its only like 30 seconds]
    https://www.youtube.com/watch?v=E6ki_8-4TI0
    after applying vegas color saturation settings, the color improved, but it’s not too sharp
    https://www.youtube.com/watch?v=ClMiEpPw3sE
    that is the result and these are the video fx I have used (this is in Vegas 11 pro)
    Sony Color Corrector [Secondary] Default
    rotate hue: 0.000
    Saturation: 2.198
    Gamma: 1.224
    Offset: 8.700
    Alpha: 1.000
    Sony Unsharpen Mask
    Amount: 0.242
    Radius: 0.032
    Threshold: 0.137
    Sony Saturation Adjust
    Amount: 1.000
    Center: 0.000
    Spread: 1.000
    Low: 0.300
    High: 0.200
    Sony Brightness and Contrast
    Brightness: 0.032
    Contrast: 0.095
    Contrast center: 0.800
    Neat Video
    Configure – Noise Filter settings
    Noise reduction amounts
    Luminance: 70%
    Chrominance: 100%
    Sharpening
    Amount: 0%
    Temporal Filter
    Radius: 1 Frame
    Threshold
    +0
    Sony White Balance
    Amount of correction: 0.305
    Brightness: 1.320
    Color Curves
    Top and bottom lines raised to its max horizontally
    Sony Color balance
    red: -0.047
    green: 0.026
    blue: 0.047
    Sony Levels
    Channel: All
    Input Start: 0.105
    Input End: 0.947
    Output Start: 0.000
    Output End: 0.968
    Gamma: 0.881
    As indicated from the second clip, its not very sharp nor is it professional. There’s still a bit of grain and the lighting looks artificial. Is there anything I can do to improve the quality of the video? Because I have a few shots like the raw.
    Malcolm Williams replied 14 years, 9 months ago 2 Members · 6 Replies
  • Frederic Baumann
    December 4, 2011 at 4:43 pm
    I have made a test with FBmn Software White Balance and Exposure (grabbing a screen capture of your Youtube video… not sure about the quality), and I have got this:
    I don’t know how was the original lighting and white balance, just tried to guess.
    Frederic
    FBmn Software 1st birthday: save up to 30 Euros on all plug-ins and bundles
    Check GPU-powered FBmn Software plug-ins to fix White Balance and Exposure issues.
    Want to learn on Sony Vegas Event Pan/Crop tool? Watch my tutorial.
    Or about Keyframes? Watch this one. French version here.
  • Frederic Baumann
    December 4, 2011 at 4:53 pm
    By the way, with these settings:
    Frederic
  • Malcolm Williams
    December 4, 2011 at 5:01 pm
    The original lighting of the video wasn’t too good. I guess I was trying to get it to appear a bit more brighter as well as sharp. It was recorded 1920×1080 by a nikon camera (but it was like a $230.00 camera)
    I have since removed the video fx and I wanted to start fresh again. I know I need neatvideo because the lighting was mediocre and neat video does get rid of noise, but I will also try the settings you linked to right now
  • Malcolm Williams
    December 4, 2011 at 6:35 pm
    this is the new output with neatvideo and the filters you suggested. The whiting is far better but is there anything that can be done to improve the sharpness?
    https://www.youtube.com/watch?v=aihX59aROUw
  • Frederic Baumann
    December 4, 2011 at 6:55 pm
    Glad to read that whiteness is far better (it actually looks so on your last clip!) 🙂
    I am not an expert about sharpness, but did you try the Sony tool? (in French it is called “Netteté Sony”, so I guess it should be Sony Sharpness in English).
    My 2 cents,
    Frederic
  • Malcolm Williams
    December 6, 2011 at 12:16 am
    here’s an update
    https://www.youtube.com/watch?v=X8n5avin9Bw&feature=youtu.be
    colors are improved grain is gone but the quality is still not so good. Is it because of the camera? iS there any editing I can do to make it look richer more crisp or something
