Activity Forums VEGAS Pro Hi Def 16×19 direct import to Vegas or render dvws?
  • Hi Def 16×19 direct import to Vegas or render dvws?
    Posted by Larry Watts on April 17, 2008 at 4:52 pm
    Is there a difference or advantage/disadvantage between importing 16×9 HiDef 1.1212 footage into a NTSC DV widescreen
    Vegas project or rendering the Hi Def footage to NTSC DV WS and importing that?
    Image quality differences is my first consideration.
    Second is file size and drive space.
    The first scenario would be working with larger files on the timeline and would render times be longer? Would the final image look better? Vegas would be converting on the fly verses rendering out new files to import.
    Any thoughts?
    Larry
    Mike Kujbida replied 18 years, 4 months ago 2 Members · 1 Reply
  • Mike Kujbida
    April 17, 2008 at 6:30 pm
    The biggest advantage to dropping hi-def footage on your timeline is that you can zoom and or pan it as needed.
    With selective editing, you can also get multiple shots from the same piece of footage.
    As I recall, the footage is the same size so you won’t gain or lose anything.
