Activity Forums Adobe After Effects Powering off an effect in several compositions
  • Powering off an effect in several compositions
    Posted by Veronica Barron on November 8, 2021 at 4:08 pm
    I have made a lot compositions of an After effects project where several layers use an specific effect.
    The time of rendering is too large, and I suppose that the reason is the use of this effect, so…
    ¿Is there a quick way to power off this specific effect in all the compositions at the same time?
    Jake Brown replied 4 years, 9 months ago 4 Members · 5 Replies
  • Meng Zhiqun
    November 8, 2021 at 5:09 pm
  • Anders Hattne
    November 8, 2021 at 5:12 pm
    “Pt Effects Search” Script..
    Seems maybe a bit pricey for what it does though.
  • Veronica Barron
    November 8, 2021 at 5:26 pm
    Thank you very much!
  • Veronica Barron
    November 8, 2021 at 5:27 pm
  • Jake Brown
    November 8, 2021 at 6:48 pm
    Hello, I just wrote a script that allows you to target a specific effect across all comps. This should work just fine for your needs.
    var effectName = prompt("Name of effect", "Hue/Saturation");
    var effectNameStr = effectName.toString();
    var projItem = app.project.items;
    var counter = 0;
    for (i = 1; i < app.project.items.length; i++) {
    // Check if item is a composition
    if (projItem[i] instanceof CompItem) {
    var myComp = projItem[i];
    // Cycle thru comp layers
    for (n = 1; n <= myComp.numLayers; n++) {
    // Test if layer has effect in question;
    if (myComp.layers[n].property("Effects").property(effectNameStr) != null) {
    var bool = myComp.layers[n].property("Effects").property(effectNameStr).enabled;
    while (myComp.layers[n].property("Effects").property(effectNameStr).enabled === bool) {
    // Toggle effects on/off
    myComp.layers[n].property("Effects").property(effectNameStr).enabled = !myComp.layers[n].property("Effects").property(effectNameStr).enabled;
    counter++;
    // Report what the script did
    if (counter > 0) {
    alert("Success! " + counter + " " + effectNameStr + " enabled/disabled");
    } else {
    alert("Could not find any instances of layers with " + effectNameStr);
