Activity Forums Adobe After Effects Script to activate or mute effects and layers from multiple pre-comp
  • Script to activate or mute effects and layers from multiple pre-comp
    Posted by Felix Henry on October 12, 2021 at 10:53 pm
    Hey i heard about a script like Dugr script but with precomp reacting to the script. So you could select effects and layers from multiple pre-comp and put them in a “folder” in this script and then activate or mutin them in one clic threw the script pannel without opening every locations.. Does it bells guys and girls ? Sanks a lot if it does
    Meng Zhiqun replied 4 years, 10 months ago 2 Members · 1 Reply
  • Meng Zhiqun
    October 30, 2021 at 2:42 pm
    For a simple way to turn on/off effects of a nested comp, you can use this after selecting that comp in your mastercomp.
    var proj = app.project; var projComp = app.project.activeItem;
    var selLay = projComp.selectedLayers;
    var foundFx = 0;
    for(var i = 0; i <= selLay.length-1; i++){
    var curLay = selLay[i];
    curLay.selected = false;
    if(curLay.source.typeName == "Composition"){
    var curSNumLay = curLay.source.numLayers;
    for(var ci = 1; ci <= curSNumLay; ci++){
    var curSLay = curLay.source.layer(ci);
    if(curSLay.effectsActive == true){
    foundFx = 1;
    break;
    if(foundFx == 1){
    for(var ci1 = 1; ci1 <= curSNumLay; ci1++){
    var curSLay = curLay.source.layer(ci1);
    curSLay.effectsActive = false;
    }else{
    curSLay.effectsActive = true;
    However, this turns All effects on all layers off and on. To keep a history of which layers in which comp has effects turned off/on before switching them, you can write a tmp text file to read later. Hope this helps!
