Activity › Forums › Apple Final Cut Pro Legacy › Here’s a new MAJOR bug in FCP7…
Andy Mees
October 9, 2009 at 12:15 pmExport clips as an FCP XML version 2 (or version 1) then reimport that XML … the clip references generated by the XML import should then be recognized by Log and Capture.
Just worked for me anyway
Best
Andy -
Andy Mees
October 9, 2009 at 2:04 pmOne more for luck, Wayne. Just tested with a simple Batch List export and import … it also worked a treat for stripping out that pesky metadata that makes FCP do its Log an Transfer thing.
Best
Andy -
Mark Maness
October 9, 2009 at 3:44 pmThank you, Andy. It’s great to see that someone else finally this out. We also figured out the Batch Export work around.
Apple dropped the ball on this one.
_______________________________
Wayne Carey
Schazam Productions
https://web.mac.com/schazamproductions
schazamproductions@mac.com -
Ben Scott
October 9, 2009 at 8:15 pmHaven’t tried it out but if there is a solution I have to say thank you forum (that’s why to check back we help each other)
XML seems to solve a lot
