Activity › Forums › Compression Techniques › Help..Sorenson Squezze introducting noise into my footage?
  • Help..Sorenson Squezze introducting noise into my footage?
    Posted by Josh J. johnson on January 30, 2008 at 9:51 pm
    when I compress my footage in sorenson with the avc codec it introduces a lot of noise that wasn’t there. Is there some kind of preset causing this? What am I doing wrong. I’m using 4.5 but when I had 4.3 this problem didn’t seem to happen?
    thanks
    Josh J. johnson replied 18 years, 8 months ago 2 Members · 2 Replies
  • Daniel Low
    January 31, 2008 at 2:01 pm
    Can you describe the noise in a bit more detail – is it like snow, blocks, fizzing, or are you referring to actual noise on the audio tracks?
  • Josh J. johnson
    January 31, 2008 at 7:43 pm
    Thanks for the reply. It’s like snow/fizzing and when I do see blocks I thing that is just a data rate issue.
    Josh Johnson
    Manager of Video Production
    ETC, Inc.
