Help with Voronoi Fracture Setup
Hi everyone,
Based on the screen recording video I attached, I am encountering the following issues:
1. I cannot figure out how to make the bottom (unfractured) part of the platonic object stay still as this is randomly moving when I trigger the shards. I am triggering using a random effector and a spherical field. The shape of the object cannot be one with a flatter base surface as this is meant to be a rock with an irregular shape later.
2. Same issue when I’m triggering using a sphere. Please see screen rec. 2. I would prefer to use this version as there should be an object coming out (revealing) from the platonic shape.
Thanks a lot. I hope I made myself clear enough. If not, please come back with any questions you may have. I’ve also uploaded the c4d scene file.
Screen rec 1 link: https://youtu.be/16BD5uzIVNQ
Screen rec 2 link: https://youtu.be/uPFL_LLuH3E
C4D Scene file: https://we.tl/t-ZxpmE2VqWC (expires in 1 week)
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
