Activity › Forums › Boris FX Particle Illusion › Help with video playback
  • Help with video playback
    Posted by Ty Emery on June 20, 2008 at 6:02 am
    Hi there, particle illusion is great and I really wan to start using it on my video projects however there is a small confusing problem. I import the regular speed video into particle illusion but it plays back at almost half speed, as if it’s slow motion or something. Does anyone have an idea of what could be happening here? Thank you!
    Elvis Deane replied 18 years, 3 months ago 2 Members · 1 Reply
  • Elvis Deane
    June 21, 2008 at 2:14 pm
    One possibility is that it’s not playing back at full speed because the clip is just really big and your system can’t play it back with all the particles at full speed. Does it play half speed once you render the project out, or only when played back in particleIllusion?
    It could also be a difference between the frame rate of your original clip and your project in particleIllusion. Double-check in the project settings that they are the same, though you should be given a warning when you are importing the video about a difference.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    Wilbur of Wumbaberry
