Activity › Forums › Avid Media Composer › Help with tricky transition
  • Help with tricky transition
    Posted by Konstantin Kostadinov on September 29, 2006 at 10:08 pm
    Hi to all in this forum
    My problem is that i have 2 shots and the transition between them is a little tricky for me so i need help
    I’m making a low budget music video for a friends
    So i have these 2 shots: A shot which is a wide shot of bunch of people and
    B shot which is two hands crushing white sheet of paper
    The idea is Shot A to be crushed by the hands in shot B using the white sheet of paper
    (I got the idea from a video
    Tech And Sway – The Wake Up Show >>> https://www.youtube.com/watch?v=v2-xIyZqv00
    The effect can be seen on 02:47
    So what did i try to do and didn’t worked:
    -Chroma Key (Very ugly and very unsuccessful)
    -Forge Reformat (Very close not good)
    -3D Warp
    I’m working on Media Composer and i have access to all kinds of plugins
    Unfortunetly i don’t know 3D
    Thanks in Advance
    Konstantin Kostadinov replied 19 years, 11 months ago 4 Members · 6 Replies
  • Michael Phillips
    September 30, 2006 at 1:38 am
    Have you tried a luma key?
    anything 24fps
  • Konstantin Kostadinov
    September 30, 2006 at 9:42 am
    Well Luma didn’t work because the sheet is white and t-shirt behind the hands is white and that’s why didn’t worked
    ______________________________________
    D**************G*******************X
  • Michael Hancock
    October 2, 2006 at 12:05 pm
    It isn’t an easy transition to do in Avid, but it can be done.
    The first transition in the piece could be done like this–shot 1 on V2, shot 2 (the guy crumpling the paper) on V1. They overlap by about 4 or 5 frames, depending on how fast your guy is crumpling the paper.
    Start by adding a resize affect to your V2 layer. About 2 frames before you want to go to the paper crumpling, keyframe the resize on the V2 layer so your layer gets a little bigger. Add a blur plugin and put a slight blur on it to simulate motion blur. Now try a warp plugin so your shot is pulled toward the center of where the paper is being crumpled. You’ll want to use a corner pin effect, keyframed so the corner of your V2 shot follows the corners of your paper as it’s pushed together. You say you’re on media composer–if parts of the paper overlap and should be blocking your V2 shot, use animatte the cut out your V2 layer, exposing your V1 paper. Continue to up your blur a little bit, and possibly add a color effect so your V2 shot becomes a little washed out and desaturated. In the video you linked the first transition at 2:47 is very very fast. You could easily size up, add a bit of blur, warp towards the center of the crumpled paper, corner pin for about 3 or 4 frames while the paper comes together and add a 3 frame dissolve at the end. It doesn’t have to be perfect–just good enough to fool the eye at full speed playback.
    Can you post an example of the clips you have that you’re trying to transition from? It would be easier to give tips is we say exactly what footage you had to work with.
    Hope this helps get you started. Post back with more questions.
    Mike.
  • Grinner Hester
    October 2, 2006 at 11:01 pm
    try distorting the A clip with a sapphire warp or somthing you have like it. Once you get the crumble alright you can animatte your hands in crushing it then bust a quick dissolve to B up full. You’ll find animatting the hands over the A shot will hide it’s obvious warpness instead of crumbleness rather well… assuming it happens quick.
    October 3, 2006 at 9:44 pm
    Hi guys
    first i’d like to thank you for helping me out
    I’ve Uploaded the shots in MEGAUPLOAD >>>
    https://www.megaupload.com/?d=EP0ZK8AH
    October 3, 2006 at 9:56 pm
    Hi guys
    BACKUP On https://download.yousendit.com/A3B7C17D5A669541
