Activity Forums Adobe After Effects Help with Trapcode Particular problem
  • Help with Trapcode Particular problem
    Posted by Maddy Mcallan on May 20, 2009 at 11:32 pm
    I want to have a smoke trail through my project like a rotating smoke entity type thing.
    I’m using a null object (3D layer) to influence the position of the smoke. I have a trail set up but in order to give it the right effect (darker edges and greyish centre) I’ve put the particle transfer to Add.
    However, this causes the smoke trail to randomly flare or change colour. The flares I learnt to live with but now as I near the end of my project the smoke has turned brown!
    I thought it was possibly due to light affecting it. I was advised to change the material options to accept lights: off. I could do this with the null object but on my solid created for the particular effect I don’t get this option. However, upon turning off light layer it seemed to make no difference to the smoke colour anyway!
    I’ve played about with every setting I can think of. Can anyone guess what could potentially be influencing the colour of the smoke or how I could create the same effect without these problems?
    Roland R. kahlenberg replied 17 years, 3 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    May 21, 2009 at 4:16 am
    Particular is applied to a 2D layer and hence it doesn’t interact with lights.
    In the Particular options dialog, there are settings for handling shadows and Blending Modes. There is also particle color (effects control panel) that may be helpful.
    Cheers
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
