Activity Forums Apple Final Cut Pro Legacy Help with the best workflow of capturing HDV and downconverting to SD
  • Help with the best workflow of capturing HDV and downconverting to SD
    Posted by Karel Hurych on March 29, 2008 at 9:40 am
    I will shoot advertising with Canon XL H 1 and MINI35 Image Converter (P+S TECHNIK).
    Camera setup is HDV 1080p, 25fr. Final master will be SD PAL 16:9 DIGI BETACAM.
    What capture setup in FCP 6.0.2 and workflow will be the best for editing in FCP, grading in Color and down-converting to SD.Can I capture direct via firewire to pro-res?
    How do the best software downconverting to SD PAL 16:9. I haven’t HD hardware like AJA or BM. I have onlz AJA Io.
    Thanks for suggestions
    KAREL
    Jerry Alto replied 18 years, 5 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    March 29, 2008 at 12:16 pm
    Use your Io to capture to ProRes. Edit… then use the Io again to transcode to SD… record that signal.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Karel Hurych
    March 29, 2008 at 2:31 pm
    I don’t understand how can I capture HDV by Aja Io?
    Thaks
    Karel
  • Jerry Hofmann
    March 29, 2008 at 6:53 pm
    Take the analog outputs from the HDV device (component of course) to the Io. And it’s audio too. There is an D/A/A/D conversion that happens doing this, but I’ve not seen a problem with it… using a Sony Deck anyway.
    Jerry
  • Jerry Alto
    March 29, 2008 at 11:54 pm
    Karel- As Jerry is suggesting use the component SD out of the camera. Go component into the Aja. If your system can’t handle the Prores codec then use 8-bit uncompressed or DVCPro50. I suggest you get all your settings correct on the camera output and the I/O (via the I/O control panel) first then launch FCP and choose the proper Easy Setup. You will be using firewire for machine control. This will give you clean SD I-frame video and not have to deal with the idiosyncrasies of editing HDV and it’s problematic mpeg2 GOP structure.
    Hope this helps.
    Jerry
    G5 Dual 3GB Ram
    FCP5 Studio
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
