Activity Forums Adobe After Effects Help with Smear Ink on a Window
  • Help with Smear Ink on a Window
    Posted by Eric Goldstein on October 18, 2007 at 1:18 am
    Hi Everyone,
    I have a shot in which a person with black ink written words on the palms of their hands wipes them on a window. I want to get the effect of the ink being smeared onto the window.
    Any thoughts on how to do this?
    Eric
    Eric Goldstein
    Giraffe Film Company
    Los Angeles
    eric@giraffefilm.com
    Eric Goldstein replied 18 years, 11 months ago 2 Members · 2 Replies
  • Kevin Camp
    October 18, 2007 at 2:19 pm
    i think i would try a particle system with some roughed up text as the particle (maybe so roughed up that it is just a texture about the same length as the text). with velocity set to zero and the postion of the emitter/producer being animated to follow the palm (maybe track the palm), it should give you something streaky. andrew’s light streak tutorial would be a good one to look at for the process i’m thinking of, but with a much simpler emitter move.
    you could even mask the particle system layer with a streaky track matte layer that you could use stock textures or just shoot your own with a digita camera for more realism.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Eric Goldstein
    October 18, 2007 at 3:04 pm
    Hi Kevin,
    Thanks for your thoughts. You gave me a good place to start.
    Eric
