Activity › Forums › AJA Video Systems › Help with setup.
  • Help with setup.
    Posted by Scott Davis on August 5, 2008 at 5:32 pm
    This is the gear I have:
    MacPro Quad Core
    6 G RAM
    Cal Digit HD One 6Tb
    OS 10.5.2
    QT 7.4.5
    FCP6.0.3
    Kona 3
    AJA HD10AVA
    Sony HDR- M15 deck
    I’m trying to digitize HDV 1080i 29.97 material DV, component out to the HD10AVA, with FW for deck control. The AJA Control Panel is showing me 1080i-29.97 in / Frame Buffer is 1080i-29.97-SDI out is 525-29.97. Easy setup is AJA 525 DV.
    I can capture DV clips but it is not downconverting the HD image to 720×480. I do have downconversion set at letterbox.
    Any help would be much appreciated. I have scoured the manual and this forum but haven’t found anything that is making it click for me.
    Thanks in advance
    Michael Sacci replied 18 years, 1 month ago 2 Members · 1 Reply
  • Michael Sacci
    August 6, 2008 at 11:42 pm
    The Frame Buffer needs to be set on Secondary (525i29.97). The way you have it set the down converting is happening to the video out.
