Activity Forums VEGAS Pro Help with playback!
  • Help with playback!
    Posted by Jono Grant on October 17, 2020 at 7:39 pm
    Hi there, I have a vegas session, 4K, with about 6 videos in the session. Minimal effects. Just levels/brightness kind of effects. I used Handbrake to re-render make sure all the videos had a constant frame rate etc.
    The thing will barely play even with the preview window set to “draft quarter”. What the heck?
    Can anyone suggest something so that I can simply work and see what I’m doing? Any help would be appreciated! Thank you
    Jono
    Graham Bernard replied 5 years, 10 months ago 4 Members · 6 Replies
  • Jeremy Rasnic
    October 17, 2020 at 7:46 pm
    Render out to a proxy file. That will allow for fluid playback.
  • Jono Grant
    October 17, 2020 at 7:53 pm
    Thanks. Not sure what you mean… I’m trying to edit the multiple clips this session contains. Do you mean render them together?
  • Steve Rhoden
    October 18, 2020 at 12:36 am
    You are working with 4k video content, you wont get smooth playback if your system is not powerful enough. Plus, the Vegas Preview window playback is not like a media player, you wont get smooth playback with everything.
    What i use is the “Dynamic Ram Preview” on sections by sections during edit, to get a perfect feedback as i go along, as to what my final render will look like.
  • Jono Grant
    October 19, 2020 at 4:27 am
    Awesome man! Works like a charm, thanks!
  • Jono Grant
    October 19, 2020 at 4:29 am
    I’m learning about proxies, thanks! The dynamic preview thing will really help in the meantime! Appreciate it! Cheers
  • Graham Bernard
    October 19, 2020 at 5:05 am
    Jono, I’m now universally using Happy Otter Scripts’s Kwik Preview. Like Shift+B, Build RAM Preview, it is also volatile but is both Faster and doesn’t take RAM away from the RAM reserve. It is STUNNING! I’m using MagicRGBA (yes, that’s MAGIC and not MAGIX!) as the encoder which is in itself blisteringly fast. Anybody making complex graphic and texture rich environments, would do well to explore it.
    Wayne is a member on this site, hopefully he’ll jump in.
    Getting your narrative/story succinct is what Editing is all about. Seeing it work on screen in the fastest way is always a boon.
