Activity Forums Avid Media Composer Help with No Frame Boundary
  • Help with No Frame Boundary
    Posted by William Landry on May 31, 2008 at 6:33 pm
    Hello!
    I have a 10minute sequence with a TIMECODE effect on the top most video track. When I go to render that effect, it quits with no error message or pop up at around 40%.
    If I try to export a QT Ref. and render effects it gives me the “exception: no_frame_boundary” pop-up error.
    If I cut up the Timecode layer into chunks around 3 minutes each, it works without a problem.
    I checked Avid’s knowledge base and the only solution I was able to find was to check that my drive’s file system is NTSC based, which it is.
    Any insights?
    Thank you.
    William Landry
    John Miller replied 18 years, 3 months ago 3 Members · 4 Replies
  • William Landry
    June 1, 2008 at 3:22 am
    Oops, NTFS not NTSC.
    William
  • Terence Curren
    June 1, 2008 at 1:37 pm
    Sounds like a size of file issue. The reason to check your drive formatting is that FAT 32 drives can only hold files 4 gigs and under.
    Are you positive it is NTFS and not FAT 32 which is also a PC format? If this is a firewire drive with the original formatting it probably is FAT 32.
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • William Landry
    June 1, 2008 at 2:08 pm
    Thank you for your reply.
    It is indeed a firewire drive, a Lacie 2BigTriple to be precise. It was reformatted and unless Windows is lying to me, it is NTFS.
    For now I have cut the Timecode effect into chunks. I had the same problem with a Submaster effect as well.
    William
  • John Miller
    June 3, 2008 at 7:11 pm
    I am having the same issue here. I have a Project that I am trying to Video Mixdown. (1hr 47min)
    Rendering to a LanShare Unity Drive so no question about Drive Format. I have routinely done large mixdowns like this before with no issue. There is plenty of drive space available.
    I have already gone through and Rendered all the effects.
    Mixing to OMFI 2:1
    Any further thoughts and discussion may be helpful. Thank you
    Avid Adrenaline
    Media Composer 2.7.7
