Activity Forums Adobe After Effects Help with my workflow
  • Help with my workflow
    Posted by Blahtor Magnus on February 2, 2009 at 4:12 pm
    I will composite 4 keyed-out humans in an After Effects composition.
    It is really hard to work with HD footage that has Keylight attached to it – even if you have only one track and even if you lower the preview quality to 1/8, still the footage slows down the machine tremendously.
    If you have not 1 but 4 tracks with Keylight attached, all of them in one composition, then I guess the computer will just stop working.
    So, is it a good workflow to key-out the different tracks, then render them and then import them back in AE?
    Is there any other, better workflow?
    Am I missing something?
    Jan Sherlink replied 17 years, 7 months ago 3 Members · 3 Replies
  • Kevin Camp
    February 2, 2009 at 4:35 pm
    [Blahtor Magnus] “So, is it a good workflow to key-out the different tracks, then render them and then import them back in AE?
    that’s the workflow i’d use…
    you can use the composition>pre-render feature to add a comp to the render queue and have ae automatically import it and replace the pre-comp with the rendered footage where ever it was used, which is really handy. it won’t delete the pre-comp or anything, so if you need to make adjustments later you can go back to the original pre-comp, tweak it and re-render the footage (with same name) and update that way.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Blahtor Magnus
    February 2, 2009 at 5:54 pm
    It will preserve the separate tracks and re-import the rendered material as separate tracks again?
    Sounds like a cool trick!
  • Jan Sherlink
    February 2, 2009 at 7:05 pm
    no need to start replacing footage,
    Queue your comp,
    make it a PSD sequence or movie with alpha channel,
    In the output module, set the post-render action to “Set Proxy”,
    after rendering your proxy will be linked automatically.
    next to your media you’ll have a proxy on or off switch.
    cya,
    Jan
