Activity › Forums › Apple Final Cut Pro Legacy › Help with MpegStreamClip
  • Help with MpegStreamClip
    Posted by Tim Baker on August 27, 2007 at 10:45 pm
    I am converting in MSC and for some reason…I have used it a lot and never run into this…my audio starts out synced just fine, but several minutes into the clip…my audio starts looking like a bad Chinese movie.
    It is driving me nuts.
    The same clip plays back fine…w/synced audio in MSC preview.
    HELP!!!
    If you could also reply to my email tim@chameleonmvp.com…I may not be monitoring the Cow as much as that one…this is pretty urgent.
    Thanks all,
    Tim Baker
    Chameleon Mobile Video Productions
    (239)849-3295
    “It is not the light at the end of the tunnel that we should seek…it is the courage to take the next step in the dark that we must find.”
    Jeremy Garchow replied 19 years, 1 month ago 3 Members · 3 Replies
  • Patrick Sheffield
    August 28, 2007 at 7:30 am
    Did you repair timecode?
    Patrick
  • Tim Baker
    August 28, 2007 at 12:02 pm
    Yes…I tried without it to…I figured maybe it was making sync worse if it was shifting things to fix timecode, but nothing has worked.
    Tim Baker
    (239)849-3295
  • Jeremy Garchow
    August 28, 2007 at 3:34 pm
    Do you have the frame rate and audio sample rate proper?
