Activity Forums Adobe After Effects Help with importing transparent backgrounds from Photoshop
  • Help with importing transparent backgrounds from Photoshop
    Posted by Aske Nielsen on May 4, 2008 at 8:30 am
    Hi
    Im making a 2d animation actionmovie, and i need some help fast!
    I painted the blood that my characters is going to spray his surroundings with in Photoshop Extended, where it is possible to draw on a sequence of images. I painted the blood on a transparent layer, and now need to import it to After Effects. I tried both rendering as a sequence of images and saving it as a psd, but there is always a black background when im importing in AE..
    All help appreciated 🙂
    Jim Money replied 17 years, 8 months ago 3 Members · 3 Replies
  • Robert Reiss
    May 11, 2008 at 5:34 pm
    I have a similar problem with a photoshop file which has transparent background, but when imported into After Effects the background becomes a solid white color.
    Have you had any luck with this situation?
  • Robert Reiss
    May 12, 2008 at 5:06 am
    Here is something to try:
    With the composition or specific layer of interest selected, hit the “toggle transparency button” which is a small gray and white checkered button at the bottom of the composition window.
    Robert Reiss
  • Jim Money
    January 4, 2009 at 10:55 pm
    i have the same problem
    have you found out how to get rid of the white background when importing transparent animated gif?
