Activity Forums Apple Final Cut Pro Legacy Help with FCP Capture settings
  • Shane Ross
    August 13, 2007 at 4:15 pm
    IN the deck (in the 800s in the menu) set the deck to output DV. Then set FCP to the DV/NTSC EASY SETUP and then capture. That should work.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Elliott Dunwody
    August 13, 2007 at 6:37 pm
    Thanks, changing the menue on the deck was the key
    Elliott
    Bright Blue Sky Productions
    4811 Rivoli Dr
    Macon, GA 31210
    http://www.brightbluesky.com
