Activity Forums Adobe After Effects Help with expression tied to Audio Keyframes
  • Help with expression tied to Audio Keyframes
    Posted by Alturo Nguyen on October 5, 2005 at 8:05 pm
    Goal, tie the position of a layer to the “Audio Amplitude” Layer (keyframes from audio data)
    Getting “expression result must be of dimension 2, not 1” error
    …Figured needed to change min/max stuff to (x,y) type of thingy…still didn’t work
    minAudio = 0;
    maxAudio = 25;
    minPosition= -1; //Tried this>> maxPosition= (1,1);
    maxPosition= 1; //maxPosition= (1, 1);
    audio=thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”)
    linear(audio,minAudio,maxAudio,minPosition,maxPosition)
    still no go
    Thank you
    Dan Ebberts replied 20 years, 11 months ago 2 Members · 1 Reply
  • Dan Ebberts
    October 5, 2005 at 9:30 pm
    Your minPosition and maxPosition variables need to be two dimensions, like this:
    minPosition = [0,0];
    maxPosition = [100,100];
    They could be any x and y values, they just need to be in the brackets.
    Dan
